Converting MULTILINE STRING to geometry
  • Nov 18, 2018 9:02 PM UTC
  • 9 replies
  • 441 views
thomastupuivao
Forum|alt.badge.img+7
I'm trying to convert a CSV file of MULTILINE STRINGS for 'road centerlines' to Geometry. I've been able to do so for the 'address points' using "stringsearcher + vertex creator" but am struggling with the 'roads' as there are multiple pairings of coordinates;
MULTILINESTRING ((-41.2762718167 173.2862863, -41.2762702333 173.2867388167, -41.2762720167 173.28681425))
Have you tried converting the text to geometry using the GeometryReplacer? It can convert the text to geometry. Choose geometry encoding OGC Well Known Text.
thomastupuivao
Do I need to use regex on the value when choosing the "geometry source", as it doesn't seem to create geometry when I use 'GeometryReplacer'??
The entire text line you posted should enter the GeometryReplacer. Including the word MULTILINESTRING and the brackets. No regex is needed.
danilo_fme
Forum|alt.badge.img+58
  • Nov 19, 2018 11:25 PM UTC
Hi @thomastupuivao
I agree with @bartjannink about the suggestion to use the transformer GeometryReplacer and your case.
Thanks,
Danilo
thomastupuivao
Okay, figured out from a different topic that by stripping the 'MULTI' as well as the double brackets, GeometryReplacer works!! Thanks again!!
scarter
Forum|alt.badge.img+10
  • Feb 24, 2023 10:08 AM UTC
Hi @thomastupuivao​ . I'm trying to do something similar., I have a csv of records each with a multlinestring value (e.g.: MULTILINESTRING ((-0.07391196 51.50043684, -0.07422012 51.50052063, -0.07426638 51.50053251, -0.0747972 51.500457, -0.07556634 51.50019987, -0.0758331 51.50015361)) ). Is it as straightforward as this...
Creator>
Feature Reader (reading the csv)>
GeometryReplacer (using encoding OGC Well Known Text and picking the field containing the multilinestring value.)>
FeatureWriter (to shp etc.)
I'm trying the above but not getting the output required. Maybe it needs a vertexcreator and coord system setter. Any tips are very welcome. Thanks.
Forum|alt.badge.img+54
  • Feb 24, 2023 10:39 AM UTC
Creator>
It should just be as simple as using the GeometryReplacer on the text value. What are the issues you are encountering? The string you posted in your example gets created as a line with that workflow with no issue
scarter
  • Feb 24, 2023 10:43 AM UTC
Thanks for , @ebygomm​ . The problem I'm having is that no geometry lines are being created. In my example I had previously stripped out the MULTILINESTRING text and the double brackets (following a suggestion earlier in the thread). Perhaps I should try it with the MULTILINESTRING text and the double brackets still in place. I'll try that now.
scarter
  • Feb 24, 2023 10:51 AM UTC
Hi. It worked with the MULTILINESTRING text and the double brackets back in place. I now need to convert to british national grid epsg:27700.
