I am working with CityGML data and using FME to process and transform buildings from a 3DCityDB into CityGML output. I know I can use the 3DCityDBImporter/Exporter for this but I would like to create a custom FME script for more control.
I am trying to transform attributes from the 3DCityDB into a format suitable for CityGML output, specifically list attributes like citygml_function{}, citygml_function{}.codeSpace and citygml_usage{}, citygml_usage{}.codeSpace. These attributes are stored as strings with values separated by --/\--, and the corresponding URLs (codeSpace) are also in a similar delimited format.
I attatch one building with these attributes in csv format as an example.
The end result should be like this feature (building):
Have anyone done something similar as this? Im not very used to working with lists. Would appreciate the help, thanks in advance!
