Converting floating point date based on 1900 Date System
  • Feb 27, 2014 9:03 PM UTC
  • 6 replies
  • 568 views
jon
Forum|alt.badge.img+5
I have a floating point number (i.e. 41165.2823011227) that I need to convert to year, month, day, hour, minute, second.  All I've been told is that the floating point number is the number of days since January 1st, 1900.  After a little bit of research, it looks like you can convert these in Excel (make sure you have 'Use 1904 date system' unchecked under Advanced Options).  When I enter the floating point number and format the cell to Date, I get 9/13/2012  6:46:31 AM which looks correct.
Is there a way in FME to accomplish this same conversion?
More info on the 1900 Date System here: http://support.microsoft.com/kb/180162
fmelizard
Forum|alt.badge.img+22
  • Feb 27, 2014 9:35 PM UTC
How about the date formatter or converter (from the FME store)?
  • Feb 28, 2014 8:59 AM UTC
[updated formatting 2022-11-08]
Excel can either use the number of days since 1900 or 1904, as you discovered. Make sure you use the correct formula.
Here is the code for a PythonCaller that will convert either of those to a formatted timestamp string:
import fmeobjects
import datetime
def xldate_as_datetime(xldate, datemode):
   # datemode: 0 for 1900-based, 1 for 1904-based
   epoch = datetime.datetime(1899, 12, 30)
   excel_date = datetime.timedelta(days=xldate + 1462 * datemode)
   return epoch + excel_date
def FeatureProcessor(feature):
   days_since_1900 = float(feature.getAttribute('date'))
   date = xldate_as_datetime(days_since_1900, 0)
   formatted_date = date.strftime('%Y-%m-%d %H:%M')
   feature.setAttribute('new_date', formatted_date)
Note the "datemode" parameter that you can set to either 0 or 1 depending of which base year you're using.
The example above expects an attribute "date" containing a float and will create a new attribute "new_date" containing a text string representation of the calculated date. You can modify the parameters to strftime to adapt the results to your needs. See here (http://docs.python.org/2/library/datetime.html#strftime-and-strptime-behavior) for more info.
Output from Logger after a run on my machine:
 'date' has value `41165.2823011227'
 'new_date' has value `2012-09-13 06:46'
Watch our for potential time zone issues, if relevant...
jon
  • Feb 28, 2014 5:24 PM UTC
Thanks David - that did the trick!
avdb
  • Jul 7, 2020 2:34 PM UTC
I have the exact same question as Jon's (Converting floating point date based on 1900 Date System)
It looks like a DateTimeConverter can solve this.
What should the "Input Format" be (it is not ISO nor FME nor Epoch which is based on 01 Jan 1970)?
Thanks!
Forum|alt.badge.img+54
  • Jul 7, 2020 4:36 PM UTC
@avdb If you didn't want to use the python already suggested you could use a DateTimeCalculator to get the date
e.g. using the 1900 date system
avdb
  • Jul 7, 2020 9:05 PM UTC
Fantastic @ebygomm, this worked great! Thanks so much for the detailed screenshot!
