Converting & Combining Shape .shp file into AutoCAD .dwg file
  • February 19, 2020
  • 6 replies
  • 44 views
I have a point vector shape file that consists of the vertices of a number of lines. The data looks kind of like this: (extremely simplified values, but the same format)
Feature NumberVertex NumberxyzLayer00101315Main Cable01121420Main Cable
10345Secondary Cable11478Secondary Cable125710Secondary Cable
What I want is to create lines that consist of x, y and z values using the feature number as the grouping attribute, ie. All points that have a matching feature number would create a single line, with the vertices starting from lowest to highest.
I have tried using CAD, FME and Excel but have had no success.
Thanks in advance!
oscard
Forum|alt.badge.img+22
  • February 19, 2020
First create the point with VertexCreator. EDIT: This step is not necessary. I thought it was an Excel as the input.
Use a Sorter to sort features by Feature Number and Vertex Number.
Then create the lines with the LineBuilder, using Feature Number as the Connection Break
  • February 20, 2020
I have attempted to follow these steps, but so far my result is not what I want (it doesn't even change the format of the beginning data).
What I was able to do was use the points to path feature in QGIS. However, the 'Layer' column is lost during the creation of the line. (I may open a new help question for this)
umapper1
Forum|alt.badge.img+5
  • February 21, 2020
Hi Nic, is that your full workspace? I can’t see the line builder or writer transformer in there.
oscard
  • February 21, 2020
What @umapper1 has said. Without the LineBuilder I have mentioned in my answer you won't see a any real change.
  • February 24, 2020
Hi Oscard,
Unfortunately, when I tried your solution, I had no success. I feel like I'm missing something, but here is the process that I have been following.
1: Import a shape file into FME
2: Apply a sorter
3: Apply a line builder
However, the result is this:
I don't think this is the result I am seeking. From what it appears, only the x, y, z values for the first vertex is being used. I want to have a geometry column that has ALL the x, y, z values for that particular line
oscard
  • February 24, 2020
Hi Oscard,
2: Apply a sorter
Could I have a sample of your SHAPE data? I have applied those steps to build lines from points without any issue.
