Converting columns to string
  • Feb 13, 2023 10:44 AM UTC
  • 390 views
Hello,
I have a table with some attributes and I created a new column which is called "Description" with the following string, by using the text editor in attribute manager :
"New values, Dat: @Value(Dat), Nat: @Value(Nat), OBJNAM: @Value(OBJNAM)"
However in some cases there are no values in all those attributes and the output looks like this:
"New values, Dat: , Nat: Underground heigh., OBJNAM: , "
I would like to exclude the attributes that don't have a value (in my example the Dat and ONJNAM), for each row.
I guess I should use somewhere a conditional formatting but I am not sure how and where to do that.
Best answer by redgeographics
They are more than 3 attributes! I just use an example here.
Also not all the rows are missing the same attributes. I will try the string replacer.
(Dat: ,|Nat: ,|OBJNAM: $)
Should do the trick as Regex (using your example). And just replace with an empty string
Forum|alt.badge.img+63
Yes, this can be solved with conditional values but it's a bit of a hassle since there's three attributes which can all be missing or not, so 6 options in total to work out.
Alternatively, you could use a StringReplacer with a regular expression, removing "Dat:," "Nat:," and "OBJNAM: ,"
  • Feb 13, 2023 11:43 AM UTC
  • Feb 13, 2023 2:53 PM UTC
Yes, it works! Thank you!
