Converting Civil 3D spatial and object data to ESRI shapefiles
  • November 3, 2017
  • 57 views
danilo_fme
Forum|alt.badge.img+53
  • November 4, 2017
Hi @devonhjenkins,
Do you want to read Autodesk AutoCAD Civil 3D and Write Shapefile? What kind of information do you want to write in shape?
Thanks,
Danilo
daveatsafe
Forum|alt.badge.img+20
  • November 6, 2017
Hi @devonhjenkins,
If you use the FME Civil-3D reader, the features read will have the Civil-3D attributes as well as the geometry, which includes the information you listed.
If you generate a new Civil-3D to Shape workspace, then run it, it will write both geometry and attributes to the output Shape file.
