Converting CityGML to Cesium 3DTiles: Problem writing Numeric Attributes as float or int
  • May 18, 2022 4:14 PM UTC
  • 47 views
I have a CityGML file with some attributes containing numbers, but also strings.
But for example, the folllowing attribute is supposed to be a float or integer in the 3DTiles format, but is written as a String, no matter what I specify as datatype in the writer's user attributes.
<gen:stringAttribute name="DatenquelleDachhoehe">
  <gen:value>1000</gen:value>
</gen:stringAttribute>
What could be the reason for the 3Dtiles writer ignoring the specified datatypes?
nampreetatsafe
Forum|alt.badge.img+14
Hi @jobot​, I took a stab at reproducing your scenario with a CityGML file containing a string attribute call DIVISION, like so:
<gen:stringAttribute name="DIVISION">
<gen:value>130</gen:value>
It seems to work and output an integer in the resulting 3DTiles dataset.   I've attached my workspace template to this comment.
Would you mind sharing your workspace and/or a sample of your output?  How are you determining that the output is a string vs. integer?
