Converting boolean to short int (or int2) errors
  • November 20, 2019
  • 36 views
fpakzat
Forum|alt.badge.img+3
I'm having this error sometimes (not always, that's the weird part) when I try to convert an attribute that has 3 possible values (0, 1, null). what is the best way of solving this problems.
Value of attribute 'isReg' could not be converted to type 'int2'. Feature will be logged and skipped
... Last line repeated 1229 times ...
chrisatsafe
  • November 25, 2019
Hi @fpakzat,
Would you be able to upload your workspace? I'd love to take a closer look into this for you. If possible, please include a bit of sample data so I can try to reproduce the same conditions. If you don't want to upload the workspace/data to the forum, perhaps you could submit a support case via the report a problem webform and our experts team can further investigate.
Looking forward to hearing back from you.
