Converting a TIF to a JPG
  • February 13, 2018
  • 5 replies
  • 272 views
I am trying to convert an image I have that is in TIF format to a JPG format. I've done it before but just forgot the path. If anyone has any suggestions of tips please let me know thank you!
Best answer by daveatsafe
Hi @sightglass26_,
Rather than the RasterSelector and RasterbandKeeper, it might be easier to use a RasterInterpretationCoercer to convert the raster to RGB32, which is suitable for JPG output.
  • February 13, 2018
Hi @sightglass26_
you need a TIFF or Geo TIFF Reader and a JPEG Writer in your workspace. After you connect the two and run your translation, you will get your source tif-file converted into JPG. You can do more using Reader and Writer parameters and/or transformers.
Please see attached. There is an 'extra bands' error. We have it set up the way you guys showed us last time, but we are getting an error.
daveatsafe
Forum|alt.badge.img+19
  • February 13, 2018
Hi @sightglass26_,
  • February 14, 2018
daveatsafe wrote:
Hi @sightglass26_,
Probably "RGB32" is a typo. I suppose that "RGB24" is intended here ;-)
daveatsafe wrote:
Hi @sightglass26_,
Dave, great! that gets us a JPG2000 file, but I can't send that to the printer. How do I get it to a standard .jpg?
