Converting a line to vertices
  • June 10, 2013
  • 1194 views
fmelizard
Forum|alt.badge.img+22
Hi Folks,
I'm having a brain-freeze - how do I convert a line to its constituent vertices resulting in an output point dataset?
Logically the GeometryCoercer should do it, but it doesn't.
CoordinateExtractor with a loop could probably do it, but that seems massively overkill for what should be a simple task. Is there a transformer I'm missing?
Thanks,
Jonathan
Best answer by david_r
Hi Jonathan,
you might be looking for the Chopper (By Vertex, max vertices:1)... Not always intuitive :-)
David
  • June 10, 2013
Hi Jonathan,
David
