convert Using XML hierarcy(parent-child id) to relational database(postgresql) tables
  • November 15, 2021
  • 22 views
kailinatsafe
Forum|alt.badge.img+21
Hello @ikubra800​ , thanks for posting to the FME community. Yes, this should be possible to do with FME. If you're new to working with XML in FME, I recommend checking out Getting Started with XML and FME tutorial. Also, we have a getting started tutorial for databases too: Let the Databases Do the Work (particularly the writing example).
If there is a specific example you are looking for, let me know. Hope these resources help, Kailin.
