Convert txt to structured Json format
  • May 14, 2020 6:52 PM UTC
  • 5 replies
  • 500 views
oumar
Forum|alt.badge.img+3
I am in new in Json file formatting and I have a flat file that contained data to be used in HTTPCaller to an API that need structured Json formatting file. I am struggling with converting my flat file into structured Json format. I tried many options and can't get it to work.
I have attached my input and desired output files
Thanks for your assistance.
  • May 14, 2020 10:33 PM UTC
Hi @oumar, you can use the JSONTemplater to convert the CSV record to a JSON text structure. This is a template expression example that convert a single row of the CSV to a JSON text.
    "logging" : {
        "sessionId" : fme:get-attribute("logging.sessionId"),
        "quoteNumber" : fme:get-attribute("logging.quoteNumber")
    "quote" : {
        "numberOfUnits" : fme:get-attribute("quote.numberOfUnits"),
        "numberOfResidents" : fme:get-attribute("quote.numberOfResidents"),
        "numberOfDogs" : fme:get-attribute("quote.numberOfDogs"),
        "numberOfGarages" : fme:get-attribute("quote.numberOfGarages")
    "filter" : {
        "formCode" : fme:get-attribute("filter.formCode"),
        "uwCompany" : fme:get-attribute("filter.uwCompany"),
        "uwTier" : fme:get-attribute("filter.uwTier"),
        "wildfireScore": fme:get-attribute("filter.wildfireScore")
See also the Help to learn more.
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Transformers/Transformers/jsontemplater.htm
Hope this helps.
daveatsafe
Forum|alt.badge.img+24
  • May 14, 2020 11:09 PM UTC
Hi @oumar,
You can use the JSONTemplater to create the output JSON that can be used in the JSON writer. I am attaching a workspace to illustrate.
csv2json.fmw
oumar
  • May 18, 2020 9:53 PM UTC
Thanks Dave and Takashi for your expertise.
oumar
  • May 18, 2020 10:51 PM UTC
Hi @oumar,
csv2json.fmw
Hi Dave,
on a follow up question, how do I feed the result into a HTTPCaller to call an API. I am able to do so just by having only 1 record in a file using Upload data = file and pointing that file with single record.CL_Underwriter_JsonExtracter_Grid_Input_json.fmwt
daveatsafe
  • May 19, 2020 3:20 PM UTC
Hi Dave,
Hi @oumar,
If you use Takashi's template in a single JSONTemplater, you will get one attribute containing the complete JSON string, that can be used as the upload string in the HTTPCaller.
