Convert SVG path format to SDO_GEOMETRY
  • April 24, 2013
  • 42 views
I am trying to read a AutoCADMap 3D .layer file which contains the following details,
<Path>
<Geom>M -130.0,130.0 L 130.0,130.0 L 130.0,-130.0 L -130.0,-130.0 L -130.0,130.0 M -130.0,0.0 L 130.0,0.0 M 82.425,0.0 A 82.425,82.425 0.0 1 0 -82.425,0.0 A 82.425,82.425 0.0 1 0 82.425,0.0</Geom>
</Path>
The Geom element has data in SVG format. I need to convert this format into Oracle SDO_GEOMETRY and store the data in Oracle spatial table.
I don't find any off-the-shelf reader/transformer. How do I perform the transformation in FME?
Regards,
Ananda
  • April 24, 2013
I think your best bet is the PythonCaller as you'll probably have to parse the SVG geometry yourself.
Have a look at the API doc in <FME>\\fmeobjects\\python\\apidoc\\index.html to get you started.
David
  • April 24, 2013
The pysvg module might also be of interest.
David
mark2atsafe
Forum|alt.badge.img+59
  • April 25, 2013
I'm not clear what the contents of the geom field are - a .layer file usually contains details of feature symbology, and looking at those geometry contents they look more like a linestyle or pattern definition to me than actual features.
Still, they are XML-like so you should be able to extract the contents of the <Geom> tag using the XMLFlattener transformer. Then you could use the AttributeSplitter to divide the data up (using <space> as a delimiter>?)
Hope this is of help
Mark
Mark Ireland
Product Evangelist
Safe Software inc
