Convert SHP to TopoJSON
  • Jan 20, 2022 7:07 AM UTC
  • 272 views
chithramc
Participant
Forum|alt.badge.img+4
Hello Dears,
Im new to FME.
I would like to convert SHP to TopoJSON. Is there any special transformers to use for this process or any customization required.
I tried with simple attribute manager but the converted data is just a line.
could you please help anyone
SC attached
Best answer by markatsafe
@chithramc​ I believe that GeoJSON (and TopoJSON) only support geographic coordinate systems - i.e. LL-WGS84. Try switching the target coordinate system to LL-WGS84 in your workspace rather than AinElAbd.BahrainGrid
@chithramc​ Welcome to FME. Do you need to reproject the data? By default GeoJSON is in geographic lat/long. So if your source SHAPE data is in a different coordinate projection you'll have to reproject. Just add LL-WGS84 to the TopoJSON writer in the workbench Navigator.
If that is not the issue, then perhaps attach a small sample of your data so someone can investigate a bit further.
  • Jan 21, 2022 5:17 PM UTC
chithramc
Participant
  • Participant
  • Jan 22, 2022 4:36 AM UTC
Thank you Mr Mark,
Your answer was very accurate and help to solve my issue. ✌️
regards
