Convert raster to vector grid, populate attributes with colours?
  • Sep 13, 2018 11:57 PM UTC
  • 203 views
nicholas
Forum|alt.badge.img+14
I have a (4KB) png file I want to convert to a vector grid. I want each pixel in the raster to be its own cell in the vector grid.
I am using RasterCellCoercer
Output Cell Geometery: Polygons
Extract Band Values As: Attributes
Extract Nodata Values: Yes
My question is how do I transfer the colour values of the raster to attribute values in the vector?
Hi @nicholas,
There is a custom transformer that can help you do this. After the RasterCellCoercer:
  1. Add an AttributeManager or Creator to create a single RGB attribute from the raster band cell values, set the new value to:
@Value(_band{0}.value),@Value(_band{1}.value),@Value(_band{2}.value)
  1. Add a custom transformer, the ColorConverter, to convert this value to FME colours
  2. Add a FeatureColorSetter and set the colour scheme to 'Fixed' and the fill color to the _output_color created by the custom transformer.
gio
Forum|alt.badge.img+15
  • Sep 14, 2018 3:08 PM UTC
You can just create an attribute
for 8bit
fme_fill_color =
@Evaluate(@Value(_band{0}.value)/256),@Evaluate(@Value(_band{1}.value)/256),@Evaluate(@Value(_band{2}.value)/256)
(use texteditor to avoid further Evaluation!!)
(fme_color for borders)
jdh
Forum|alt.badge.img+41
  • Oct 12, 2018 8:21 PM UTC
for 8bit
fme_fill_color =
Wouldn't that be divide by 255? The 256th value is 0.
