Convert raster and delete old file?
  • Jul 26, 2019 2:08 AM UTC
  • 63 views
nicholas
Forum|alt.badge.img+14
I have a directory containing several hundred raster images in geotiff format
I would like to convert them to ecw format
As file space is limited, I would prefer to;
- iterate through the geotiffs one by one
- convert a geotiff into an ecw, saved in the same directory
- delete the original geotiff
- move onto the next geotiff
Can anyone outline the structure of a workbench that does this?
Thanks
  • Jul 26, 2019 4:46 AM UTC
Hi @nicholas, a possible way is:
  1. Create a workspace that converts a single GeoTIFF to an ECW.
  2. Create another workspace: read GeoTIFF file paths in a specified folder with a PATH reader, call the first workspace with a WorkspaceRunner (Wait for Job to Complete: Yes) to convert GeoTIFF to ECW, and remove the source GeoTIFF file whenever a translation completed.
The second workspace looks like this.
# PythonCaller Script Example: Remove a file.
import os
def processFeature(feature):
    os.remove(feature.getAttribute('path_unix'))
nicholas
  • Jul 29, 2019 11:32 PM UTC
I have it almost, but not quite, working
There is an error with the PythonCaller
WorkspaceRunner: Successfully ran workspace `D:/2019/07/tif2ecw/geotiff2ecw.fmw'
PythonFactory failed to load python symbol `FeatureProcessor'
Factory proxy not initialized
PythonCaller(PythonFactory): PythonFactory failed to process feature
Path Reader: Closing the PATH Reader
Translation FAILED with 4 error(s) and 1 warning(s) (0 feature(s) output)
My settings for the PythonCaller are;
Class or Function to Process Features: FeatureProcessor
import os
os.remove(feature.getAttribute('path_windows'))
  • Jul 30, 2019 3:05 AM UTC
import os
You have to set the name of function or class which you intend to execute - "processFeature" in my example - to the Class or Function to Process Features parameter in the PythonCaller.
See also the help on the transformer: PythonCaller
nicholas
  • Jul 30, 2019 5:30 AM UTC
I have found a solution, which is to replace the PythonCaller with a SystemCaller.
This works for me, because the dos command is quite simple
del @Value(path_windows)
I realise that PythonCaller is more flexible, but I don't know Python well enough to make it work
