convert one point into multipoint
I have a dataset containing different points. To insert them into my postGIS database I need to convert each point into multipoint (but each multipoint is only containing one point)
I may not change the geometry-type in postGIS, so I just need to store each point as a multipoint...
I already did some tests with the aggregator and geometrycoercer, but can't figure out how to change the geometry from point into multipoint.
maybe a bit of a silly question, but I just can't figure out how to do this :(
thanks for helping me!
Best answer by ebygomm
In my experience if you aggregate a point geometry it becomes a multipoint if you have the mode set to geometry assemble one level
Forum|alt.badge.img+40
  • July 14, 2017
  • July 14, 2017
weird... I do not know what I did before, but I became an aggregate-collection before...
thanks, aggrator, with the "geometry assemble one level" and group by unique id, did the trick!
