Convert multiple ESRI shape files into SQL Server Geography
  • Jun 19, 2019 3:14 PM UTC
  • 176 views
I have a number of ESRI shape files that need Sqlising. Each shape file goes into a SQL Server Database table as a single row. How do I achieve this in one workflow? Doing these one by one is not practical as there are hundreds of shape files and I can easily make a mistake plus not repeatable.
Best answer by erik_jan
Two ways of doing this:
1) Point the Shape reader to <your folder>\\*.shp to read all Shape files in one go
2) Create a workspace to process 1 Shape file and a "runner" workspace using a "Directory and File Path" reader. This reader gets the file names (shp files) and not the contents. Follow the reader by a WorkspaceRunner transformer to call the workspace for processing a Shape file and pass the attribute containing the file name to the parameter in the WorkspaceRunner. This will create a loop to run the same workspace for each Shape file in the folder.
Option 1 is the easier, option 2 more flexible.
Hope this helps.
erik_jan
Forum|alt.badge.img+26
  • Jun 19, 2019 3:38 PM UTC
Hope this helps.
rahulsharma
Forum|alt.badge.img+12
Hi @chapmans1982, As erik_jan mentioned both the above-mentioned steps would work, but just want to clarify the following
Incoming shapefiles have identical SCHEMA
Or else, the schema will be taken from the 1st incoming features and geometry and attributes will be written to same SQL table.
Under MSSQL Spatial Writer --> Parameters --> SpatialType > Set Value to Geography
Please find attached Template using FME tutorial data esrishape2mssql_spatial.fmwt
