Convert military time
  • Nov 2, 2018 8:43 PM UTC
  • 78 views
I have a date field called 'Date Started' and a text field called 'Time Started' in military format.Based on those two, I'd like to create a new column called 'Date Time Combo' (shown above) in the following format: mm/dd/yyy hh:mm AM/PM.
What's the best method to achieve this?
danilo_fme
Forum|alt.badge.img+58
  • Nov 2, 2018 9:22 PM UTC
Hi @mariofederis
I simulated here:
Atached the Workspace.
Workspace_DateTime.fmw
Thanks,
Danilo
  • Nov 3, 2018 3:02 AM UTC
I would recommend you to learn the powerful and flexible FME Date/Time functions in FME 2017.1+.
Example 1
Example 2
  • Nov 4, 2018 4:45 AM UTC
Example 1
Example 2
Found another expression that returns date/time string with your desired format.
@Value(Date Started) @DateTimeFormat(@Format(%04d00,@Value(Time Started)),%l:%M %p)
