Convert julian calendar to YYYYMMDD for images
  • Aug 14, 2018 3:19 AM UTC
  • 7 replies
  • 138 views
hoa_le
I have a image folder (.TIF) which the structure MODIS_2017001.tif, MODIS_2017009.tif, MODIS_2017017.tif,...
My target want to convert julian calender to YYYYMMDD.
For example : MODIS_2017001 -> MODIS_20170101; MODIS_2017009 -> MODIS_20170109; MODIS_2017017 -> MODIS_20170117
Could you tell me how to the way to make it?
Thank you
Best answer by takashi
Hi @hoa_le, do you perhaps mean "day of year" (001-365 or 366 in a leap year)? If so, you can convert the date format from "YYYYDDD" to "YYYYMMDD" with the DateTimeConvertor.
  • Input Format: %Y%j
  • Output Format: %Y%m%d
  • Aug 14, 2018 3:34 AM UTC
How did you determine that the source dates (2017001, 2017009, 2017017) belong January?
hoa_le
  • Aug 14, 2018 3:38 AM UTC
Yes. I use julian calender 2017 to compare. I have a excel file colums : 001 -> 0101, 009 -> 0109...
  • Aug 14, 2018 3:45 AM UTC
hoa_le
  • Aug 14, 2018 4:24 AM UTC
Yes. But if my file structure: MODIS_2017001_h28v07.
When I use DateTimeConvertor, I have to use SubstringExtractor to extract date (2017001) and extract string and create new attribute as figure but It writes to 3 files.
It seems SubstringExtractor is not corectly.
  • Aug 14, 2018 4:35 AM UTC
If the input string always consists of three parts separated by underscore, you can split it and save the parts into a list (e.g. "_list{}") with the AttributeSplitter, convert the date format of the middle part ("_list{1}") with the DateTimeConverter, then concatenate the three elements of the list with the ListConcatenator.
  • Aug 14, 2018 4:47 AM UTC
This screenshot illustrates my intention.
hoa_le
  • Aug 14, 2018 7:06 AM UTC
Thank you so much @takashi
