Convert Feature to Attribute
  • Jun 25, 2019 3:15 PM UTC
  • 111 views
bubblebeb
I have flattened some JSON and it now shows as a separate feature for each object.
This is the JSON
And this is it flattened from the JSONFlattener
I want to get the json_index to be the attribute header and the _response_body to be the feature attribute.
These are the settings I currently have for the JSONFlattener.
Any assistance on this would be great. I am in unfamiliar territory with JSON.
Thanks
geosander
Forum|alt.badge.img+7
  • Jun 25, 2019 6:49 PM UTC
You need to pivot your "table". An AttributePivoter might work or could try the custom AttributeTransposer on your JSONFlattener output maybe?
