Convert Epoch Time fails
  • December 10, 2024
  • 44 views
marta.podsiad
Forum|alt.badge.img+9
I cannot convert Epoch time 1717500804837 to 20241210. I have change the format using @Evaluate(@Value(_created)/1000)
and run DateTimeConverter but it failed
Null, empty, or missing datetime was found. Enable the passthrough parameter to disable this
What am I doing wrong?
Best answer by redgeographics
There’s a long-standing bug in the DateTimeConverter, if you select the attribute to be converted via the triangle button it’ll put the literal text @Value(...) instead of referencing the attribute.
If you select the attribute using the [...] button it’ll work.
Forum|alt.badge.img+49
  • December 10, 2024
