convert DGN igds_3d_solid to 2d
  • Jul 30, 2019 12:20 AM UTC
  • 124 views
My client has several dgn files that contain 3d_solid objects (pipelines and other vector data). I have a workbench on our FME Server that will convert drawings into shapefiles but the solid objects are not going through. The igds_type is igds_3d_solid until I try aggregate them or assign them to 3D or 2D.
One thing I also notice is that on some of the geometries not reading through the igds_type does not equal the fme_geometry. For example, I look at the dgn before processing and one of the vectors is igds_type = igds_line, but the fme_geometry = fme_polygon.
andreaatsafe
Forum|alt.badge.img+17
Hi @tsurveyor,
When you are writing the data to shapefile, are you handling both 2D and 3D geometry types at the same time? If you are wanting to convert the solids to 2D, I think you'll want to use a 2DForcer and/or GeometryCoercer to coerce the solids to 2D (lines?).
The Shapefile writer has a parameter "Output Dimension" that defines the dimension of the features which is by default set to "Dimension From First Feature" so if you are handling 2D data at the same time, I suspect the 3D solids are getting rejected because of this parameter. Perhaps if you have multiple geometries this is parameter is affecting writing out the 3D data. Regardless, if you are wanting to have the solids represented in 2D, you'll need to force/coerce the 3D data into 2D prior to write.
Would be good to see the workspace too, if you are able to share it here. If not, please submit a report via report a problem.
As for the igds_type and fme_geometry not matching, what version of FME are you using? If you are using the latest FME 2019.1, and this is occurring, we'll want to look into this further. If you can share a sample DGN file of this happening that would be great (either on the forum or via the report a problem page).
- Andrea
  • Aug 2, 2019 8:21 PM UTC
Hi @tsurveyor,
- Andrea
Thanks Andrea. I can't post the workbench here but will send the files. The transformers I tried are 3DForcer, 2DForcer, GeometryValidator, SurfaceNormalExtractor, GeommetryCoercer.
