conversion
  • Jul 9, 2019 2:46 PM UTC
  • 5 replies
  • 89 views
kathir
Hi, I have the dgn file.that consists of polygons and text(Like Prj) i want to convert that into .shp format. create the new attribute like name. that name include the shape (polygon also). what transformer used for that. how can i convert that
fmelizard
Forum|alt.badge.img+22
  • Jul 10, 2019 5:27 AM UTC
Hi @sundari Use the PointOnAreaOverlayer - assuming that the insertion point for the annotation is inside the polygon and a 1:1 relationship. You'll likely need to rename the annotation attribute afterward.
kathir
  • Jul 11, 2019 4:37 AM UTC
hi, actually i will try the PointOnAreaOverlayer transformer. i need single output in final how can i join that?In the final output shows the attribute table contains the text . if we click attribute it shows corresponding polygon in dataview. how can i convert.
kathir
  • Jul 11, 2019 7:49 AM UTC
hi,
here i had attached my source data. i need output in esri shp format. based on the text string the areas will joined. In the attribute table contains text strings the data view shows that corresponding areas.can you help me that?shivpuri 02-KM1298-KM1290 .dgn
pratap
Forum|alt.badge.img+12
  • Jul 11, 2019 8:03 AM UTC
Kindly find the workspace attached
Hope it helps
dgn2esri.fmw
kathir
  • Jul 11, 2019 8:40 AM UTC
Hope it helps
dgn2esri.fmw
thank u soo much
