Control FME Desktop memory usage
  • May 29, 2018 3:43 PM UTC
  • 92 views
I am running a Workspace and after a while it gives an error and as if the memory had burst, is there any way to control memory?
Best answer by david_r
My top six tips, in no particular order off the top of my head:
  • Unblock your transformers as much as possible
  • If you have multiple writers, replace them with FeatureWriters
  • Only read what you need, where-clauses are your friend
  • Let the database do the heavy lifting, e.g. a join on two database tables is a whole lot quicker than a FeatureMerger
  • Only keep the attributes you need at each step of the way (AttributeKeeper, yay)
  • Try to avoid the ListExploder on huge numbers of features/items, if possible
Also, consider 64-bit FME.
  • May 29, 2018 3:48 PM UTC
  • May 30, 2018 10:37 AM UTC
In addition to the above,
  • try avoiding Data Inspectors or keep it at places, only where you need it
  • check space on your hard disk
  • In Tools-->FME Options-->Translation set Translation Priority to HIGH, in case, your are running some concurent tasks.
