Connect vertices with line
Hy
I nee to connect opposite vertices within certain distance tolerance and then calculate the middle point off the connected line
Thx
Francesco
mark2atsafe
Forum|alt.badge.img+49
  • October 12, 2018
The Snapper - or AnchoredSnapper - transformer will help you connect lines within a certain tolerance.
  • October 12, 2018
NeighborFinder is also worth looking at as it logs the distance and the angle to the neighbour.
