Conditional Values for Rule Configuration in AttributeValidator
  • Nov 17, 2023 5:58 AM UTC
  • 144 views
no_id
I'm building a data validation tool and utilising the AttributeValidator heavily as part of the process. There are a couple of attributes that are "optional" but have an associated list of valid values (field validation/domain). This means they are allowed to be null, but if they have a value, it must be one of the pre-defined valid values.
I'm hoping to use the Conditional Value option for Rule Configuration as below:
FME_Screen
However, upon running the workbench, FME terminates and the translation fails immediately due to "unbalanced quotation marks on line XXXX of file <workbench directory>\\wb-xlate-1700200438336_13788". Is this a bug or is my conditional value rule configuration just incorrect?
asprague
Forum|alt.badge.img+4
  • May 14, 2024 8:40 PM UTC
I have also came across the same error when setting up a conditional check on a fme_parameter value containing a value to determine which rule configuration to use. I am suspecting that it is an unresolved bug with the transformer that should be submitted for evaluation.
