Is there a way to aggregate based on a condition?
I have a set of polygons that I want to aggregate based on the distance. That has worked with the workaround @takashi has posted numerous times (with the buffer, en the count etc). But now I end up with aggregates that have a larger summed attribute value than I would like. Is there a way to add conditions to the aggregating proces? As in, form an aggregate based on distance, but if the summed attribute value exceeds a certain amount, further separate the aggregates.
