condition in XML Templater
  • Apr 18, 2018 11:29 AM UTC
  • 145 views
I'm trying to figure out seemingly easy condition in XML Templator, but something is just not working out.
What I would like to do is write out an XML element only if a feature attribute has a value.
Here's an example:
<OperatingTimeList>
<OpeningTime>{fme:get-attribute("opening_time")}</OpeningTime>
<ClosingTime>{fme:get-attribute("closing_time")}</ClosingTime>
<OperatingTime dayOfweek="" note="we are open">
</OperatingTime>
</OperatingTimeList>
And I would like the "note" to show up in the XML only when there are some values in OpeningTime
I know I should follow if then else logic, but so far I'm only getting XMLTemplater errors.
(FME Desktop 2018)
Thanks,
Linda
Best answer by takashi
Hi @llindish, the syntax error seems to be caused by wrong usage of "fme:has-attribute" and "fme-get-attribute" functions.
If you want to create the "OperatingTime" element only if the "opening_time" attribute exists and the "closing_time" is not empty,  this expression could work for you.
<OperatingTimeList>
        if (fme:has-attribute("opening_time") and not(fme:get-attribute("closing_time") eq ""))
            then <OperatingTime dayOfweek="" note="we are open" />
            else ()
is equivalent to
fme:get-attribute("closing_time") ne ""
  • Apr 18, 2018 11:45 AM UTC
In order to clarify where the issue is, could you please post the template expression you defined and the error messages you got?
  • Apr 18, 2018 12:10 PM UTC
Hi @takashi, thanks for the quick response.
This is the expression:
<OperatingTimeList>
<OperatingTime dayOfweek="" note="">
{ if( fme:has-attribute{fme:get-attribute("opening_time")} and
not(fme:get-attribute{fme:get-attribute("closing_time")} eq "") )
then <OperatingTime dayOfweek="" note="we are open">
else ()
</OperatingTime>
And the error messages:
XMLTemplater(XMLTemplaterFactory): The following error occurred near line 403, column 43 of the query:
XMLTemplater(XMLTemplaterFactory): invalid expression: syntax error, unexpected ExprSingle (missing comma "," between expressions?)
XMLTemplater(XMLTemplaterFactory): An error occurred while parsing the ROOT template
XMLTemplater(XMLTemplaterFactory): A fatal error has occurred. Check the logfile above for details
A fatal error has occurred. Check the logfile above for details,
  • Apr 18, 2018 12:47 PM UTC
<OperatingTimeList>
            else ()
is equivalent to
  • Apr 18, 2018 2:00 PM UTC
<OperatingTimeList>
            else ()
is equivalent to
Thank you, works perfectly now!
