Concatenator code
  • Nov 8, 2018 8:22 PM UTC
  • 14 replies
  • 64 views
ingalla
Forum|alt.badge.img+10
I have been given the following python code but get errors every time i try to run it, anyone know what is wrong...
import fmeobjects
def FeatureProcessor(feature): to_concatenate = ("buildingNumber", "throughfare", "dependantthroughfare")
# Modify as needed
join_string = ","
# Modify as needed
result = join_string.join([feature.getAttribute(attr) \\
for attr in to_concatenate if feature.getAttribute(attr)])
feature.setAttribute("CONCATENATED", result)
  • Nov 8, 2018 8:38 PM UTC
What error is logged?
jdh
Forum|alt.badge.img+41
  • Nov 8, 2018 8:51 PM UTC
Does it work if you separate the list comprehension into for and if components?
ingalla
  • Nov 8, 2018 8:57 PM UTC
Here are the errors
Python Exception <SyntaxError>: unexpected character after line continuation character (<string>, line 7)
Error executing string `import<space>fmeobjects<space><space><space><lf>def<space>FeatureProcessor<openparen>feature<closeparen>:to_concatenate<space>=<space><openparen><quote>buildingNumber<quote><comma><space><quote>throughfare<quote><comma><space><quote>dependantthroughfare<quote><closeparen><space><lf>#<space>Modify<space>as<space>needed<space><space><space><space><space><lf>join_string<space>=<space><quote><comma><quote><space><lf>#<space>Modify<space>as<space>needed<space><space><space><space><space><lf>result<space>=<space>join_string.join<openparen><openbracket>feature.getAttribute<openparen>attr<closeparen><space><backslash><space>for<space>attr<space>in<space>to_concatenate<space>if<space>feature.getAttribute<openparen>attr<closeparen><closebracket><closeparen><space><space><space><lf>feature.setAttribute<openparen><quote>CONCATENATED<quote><comma><space>result<closeparen>'
Factory proxy not initialized
PythonCaller(PythonFactory): PythonFactory failed to process feature
  • Nov 8, 2018 9:04 PM UTC
Could you please repost the script as-is, using a code block?
ingalla
  • Nov 8, 2018 9:08 PM UTC
import fmeobjects
def FeatureProcessor(feature):to_concatenate = ("buildingNumber", "throughfare", "dependantthroughfare")
# Modify as needed
join_string = ","
# Modify as needed
result = join_string.join([feature.getAttribute(attr) \\ for attr in to_concatenate if feature.getAttribute(attr)])
erik_jan
Forum|alt.badge.img+26
  • Nov 8, 2018 9:10 PM UTC
Could this be solved by replacing the PythonCaller by a StringConcatenator transformer?
That seems so much easier.
jdh
I would expect the code to work with the following formatting
import fmeobjects
  Â  to_concatenate = ("buildingNumber", "throughfare", "dependantthroughfare")
  Â  # Modify as needed
  Â  join_string = ","
  Â  result = join_string.join([feature.getAttribute(attr)\
  Â  feature.setAttribute("CONCATENATED", result)
jdh
  • Nov 8, 2018 9:14 PM UTC
import fmeobjects
  Â  join_string = ","
ignore the Â, that's a problem with the knowledgebase upgrade.
Put to_concatenate on a separate (indented) line from the function definition.
Either break the list comprehension line, or don't, if you do there can be nothing after it.
or
result = join_string.join([feature.getAttribute(attr)for attr in to_concatenate if feature.getAttribute(attr)])
in the second case, it's all on one line.
jdh
  • Nov 8, 2018 9:16 PM UTC
I am assuming they don't want ,, when the attribute is empty/missing.
erik_jan
  • Nov 8, 2018 9:27 PM UTC
Then create an attribute for the concatenation character, like this:
And the StringConcatenator to do the magic:
geosander
Forum|alt.badge.img+7
  • Nov 8, 2018 10:44 PM UTC
You could also use this code:
import fmeobjects
def get_attributes(feature, attr_names):
  Â Â for attr_name in attr_names:
  Â  Â  Â  value = feature.getAttribute(attr_name)
  Â  Â  Â Â if value:
  Â  Â  Â  Â  Â Â yield value
  Â Â # Modify as needed
  Â  result = ",".join(get_attributes(feature, to_concatenate))
I'm not a big fan of list comprehensions in this particular case, because they call feature.getAttribute() twice, which is unnecessary. This is why I created the generator function get_attributes(), which only returns the attributes with a "truthy" value.
Please be aware that if the feature attribute contains the number 0 (stored as integer or float), this value is considered to be "falsy", which means that it will not be concatenated in the result. What's worse though, is that the script will choke on the str.join() call if 1 or more attributes aren't string values (which is actually what your attribute names suggest).
To tackle both problems, you could replace the get_attributes() function with this block:
  Â  Â  Â Â if value not in ('', None):
  Â  Â  Â  Â  Â  yield format(value)
This will work as long as you don't have any non-ASCII characters in your attributes...
geosander
  • Nov 8, 2018 10:46 PM UTC
import fmeobjects
  Â  Â  Â Â if value:
Oh dear, this new <code> style formatting in the Knowledge Base is absolutely horrible...
  • Nov 9, 2018 8:18 AM UTC
I agree, it's really terrible. I think Safe is working on it, however...
  • Nov 9, 2018 10:54 AM UTC
Alternatively, FME String functions might be helpful. e.g.
@ReplaceRegEx(@Trim(@CurrentAttribute(),","),",{2,}",",")
