I have a table of Well lithologies containing some logical inconsistencies that I've pulled out with the Matcher. The table has fields Well_ID, ToDepth, Color, Description, Material. It contains multiple records for a given well and depth which I want to merge into a single record. So for instance, I might have the following two records:
Well_ID ToDepth Colour Description Material
1300186 62 Green Hard Shale
1300186 62 Gray Sandy Shale
I want to produce a single record that concatenates the Color and Description values, like so:
1300186 62 Green *AND* Gray Hard *AND* Sandy Shale
Ultimately I want to stream these records back into a clean (no more duplicates) Well Lithologies table. Is the Feature Merger the way to do this, and if so, how do I configure it? Any help would be appreciated!
Thanks, Joan
