Concatenate fields with comma but exclude if a field is empty
  • Feb 13, 2024 11:15 AM UTC
  • 380 views
chris_acc
Forum|alt.badge.img+5
Hello,
I am using the String Concatenator to join two fields and separate them with a comma.
However some fields are blank so I end up with some records that contain a comma only and others that contain a comma and then the value of one of the fields.
My current setup looks like below
generally works well, except for some results like these
Is it possible to modify existing Transformer or is a different one more suitable?
My only other thought is to perform some sort of trim on an other transformer after this one to remove first character?
Thank you
Best answer by nielsgerrits
Yes. I think I could solve this using the AttributeTrimmer.
nielsgerrits
Forum|alt.badge.img+67
  • Feb 13, 2024 11:45 AM UTC
chris_acc
  • Feb 13, 2024 11:52 AM UTC
It seems to work 😊
Β
