Compound Curve problem
  • January 15, 2015
  • 7 replies
  • 184 views
Hello!
I am trying to convert COMPOUNDCURVE to FME_line but the GeometryFilter transformer wont recognize COMPOUNDCURVE as an ARC :( I am managing a PostGIS database and i found a temporary SQL-fix: http://www.postgis.org/docs/ST_CurveToLine.html (http://www.postgis.org/docs/ST_CurveToLine.html)
Any ideas? :)
Best regards,
AlexG
fmelizard
Forum|alt.badge.img+21
  • January 15, 2015
I think you will have to deaggregate the feature first.
  • January 15, 2015
The GeometryFilter seems to treat a composite curve like the COMPOUNDCURVE as a Line geometry, even if every component is arc.
If you send the feature to Data Inspector, what kind of geometry type is detected?
Takashi
  • January 15, 2015
I have tried using 2DForcer --> Deaggregator --> GeometryValidator --> Intersector and GeometryValidator in an array. GeometryFilter --> GeometryCoercer won't work either. I don't know exactly which object that is failing becaus i generate the PK when i do the DB uppload. I have 1372106 features and 12 Compound Curve ;P
fmelizard
  • January 15, 2015
I would try the TopologyBuilder > GeometryFilter, any improvement?
gio
Forum|alt.badge.img+15
  • January 15, 2015
As Takashis said, its not a compositon of (solely) arcs. The compound curve will be treated as a fme_line.
So you should see the cc output at the line output of the Geometryfilter.
  • January 16, 2015
Ok, this confirms my suspicion about the GeometryFilter :P I will try the TopologyBuilder :)
gio
  • January 21, 2015
you could expose the attribute and test on the fme_type.
Look in the navigator wich attribute to expose (or use directly)
