Comparing LAS (pointcloud) files
Hi, I have 2 LAS (pointcloud) files that have differences in classification of the points into different classes. What would be the quickest/easiest way to compare that files and output the differences into another LAS file please
Best answer by danilo_fme
Hi @tadekfigura,
I did search with more details in Safe Site and has the Webinar section.
In this section has a interesting Webinar How to Get the Most Out of LiDAR Data.
The transformer PointCloudMerger is good in your case. You can do download the Workspaces from this webinar above and see how can use it.
Documentation PointCloudMerger
Thanks,
Danilo
danilo_fme
Forum|alt.badge.img+57
Hello @tadekfigura,
did you try use the transformer ChangeDetector? It is possible to compare 3D elements:
Thanks,
Danilo
danilo_fme
  • August 30, 2017
Hi @tadekfigura,
Thanks,
Danilo
  • August 30, 2017
Are x, y, z components of all points in the second point cloud exactly equal to those of all points in the first point cloud?
  • August 30, 2017
Yes the x,y,z, components are the same. The difference is only in assigning the points to different classes. For example in one file some points are in class "ground" in the other the same pointas are in class "vegetation". I want to get a new file cointationg only the difference in that case the vegetation that was classified from class ground.
  • August 30, 2017
OK. I think the PointCloudMerger might help you. as @danilo_inovacao suggested.
For example, the transformer with this setting routes the points having the same classification to Merged and Referenced port, routes the points having different classification to NotMerged and Unreferenced port.
If you need to process only specific classes such as "ground" and "vegetation", you can use the PointCloudFilter to filter points within the source point clouds.
  • August 30, 2017
Thank you guys!
danilo_fme
Thank you guys!
You are welcome @tadekfigura !
Good teamwork @takashi :)
