Comparing 2 datasets
  • November 6, 2013
  • 1135 views
Here is the scenario
1.  I am getting some data (ie. manhole data in .shp format)
2.  I use FME to transform the data to fit into a feature dataset in our SDE server
3.  A year later I get a new .shp of the same data from #1
Does FME have the ability to compare what is in SDE with the new .shp and only import the features from #3 that are different from what is already in SDE??  Either attributes, spatial, or both may have changed.
In the time between #2 and #3 there could have been edits to the data in both SDE as well as in the .shp.
I guess it's sort of an SDE Reconcile/Post.
fmelizard
Forum|alt.badge.img+19
  • November 6, 2013
the short answer is yes it does :) look for crc matcher and the change detector.
the are some issues you should consider such as the definition. Of a changed object  and decimal accuracy for a start.
Itay
  • November 7, 2013
you can also consider the Matcher transformer.
David
