Compare every single word from one attribute with the content of second attribute.
  • Oct 23, 2017 2:35 PM UTC
  • 123 views
Hello kind people,
I am beginner with FME. I am working with data which were combined based on the similarity of the records. However, this matching is not perfect and manual review has to be done. I want to automate the review and I have question concerning comparing two records.
I would like to ask if there is any function which is able to compare two attributes for the same record e.g
NAME 1: KROGER STORE 456
NAME 2: KROGER FUEL CENTER
It would pass the test, where one word from the NAME 1 (Kroger) is dectected and included into NAME 2. Or word from NAME 2 is detected into NAME 1.
It should base on extracting every single word/number from NAME 1/NAME2 and comparing with every single word/number from NAME2/NAME1.
I will be grateful for help.
danilo_fme
Forum|alt.badge.img+58
  • Oct 23, 2017 3:28 PM UTC
Hi @vid,
I suggest you the use of custom transformer FuzzyStringComparer .
This transformer compare by similarity two attributes.
I simulated here in my machine two attributes:
After i compare using this transformer. The result of similarity will be in a output attribute: _result
Thanks,
Danilo
gio
Forum|alt.badge.img+15
  • Oct 23, 2017 3:38 PM UTC
use a string searcher on both attributes to get the "words".
Regexp: \\s*(\\w+)\\s*
Set all matches and submatches. Explode lists to separate outputs.
Merge both outputs unconditionaly (1=1).
Now u can use a tester to test word1 = word2.
(Alternatively you can use listconcatenator on one list and then use an "IN" in the tester.)
