compare 2 lists with a transformer
  • Jun 26, 2024 1:10 PM UTC
  • 125 views
alc33
Forum|alt.badge.img+14
Hi!
Does it exist an easy way (1 transformer) to compare 2 lists from differents dataset ?
For example :
dataset 1 - feature 1
list{0}.NAME = A
list{1}.NAME = B
dataset 2 - feature 1
list{0}.NAME = B
list{1}.NAME = C
I would like to have the difference so here :
=>on the dataset1, feature1 “A” is missing
=>on the dataset2, feature1 “C” is missing
the index of the value doesn’t matter, juste the presence of the value is important.
I succed with 2 ListExploder and 1 FeatureMerger, and I imagine It would be working too with  ListExploder, FeatureMerger and ListSearcher, but maybe it exist a transformer to do that more quickly.
Thanks!
Best answer by lambertus
Hi @alc33 before I red your solution I also thought about ListExploder combined with FeatureJoiner or Merger, maybe you can create a useful custom transformer to do this in one tool? :)
lambertus
Forum|alt.badge.img+25
  • Jun 26, 2024 2:24 PM UTC
alc33
  • Jun 26, 2024 3:08 PM UTC
@lambertus Thanks for your answer!
Effectively, I didn't think about it. If that transformer doesn’t exist, I could create it for ulterior use 😊
