Combing routes from the ShortestPathFinder?
  • May 29, 2019 9:18 AM UTC
  • 93 views
I have 70,000 routes which I need to combine into one layer/ network. So where the lines overlap I want to simplify that to one line. The intersector does this, but its been running since friday (6 days) and still hasn't merged them yet.
Can anyone suggest a way to tile this process maybe, or any other way to speed up the processing?
Best answer by ebygomm
It may be too late now, but in the shortest path finder, i would build a list for each route that contains a unique id identifying the path segment. Once you have all your routes, you can then explode and deduplicate the list and build geometries from the original network using the unique id
Forum|alt.badge.img+54
  • May 29, 2019 9:20 AM UTC
  • May 29, 2019 9:49 AM UTC
Thanks this works
