Combiner PointCloud files with different times
danilo_fme
Forum|alt.badge.img+45
The source my customer is PointCloud files ( 4 files ) and these files has different times, for example:
  • File A = was caught on the day 08/12/2015
  • File B = was caught on the day 10/11/2015
  • File C = was caught on the day 22/12/2015
  • File D = was caught on the day 02/03/2016
I know that the transformer PoinCloudCombiner is perfect to do this "mosaic" between Pointclouds.
My question is: How the FME works to do a interpolation / mosaic for these 4 files - PointClouds with different times? Do I need to some advance configuration in this transformer PointCloudCombiner?
Thanks,
Danilo
Best answer by nathanatsafe
Hi @danilo_fme,
Do I understand correctly that these point clouds occupy the same geographic space, but were simply captured at different times, and you wish to ignore the geographic space and patch them together?
One solution to this problem (maybe not the most elegant) might be to offset File B, C, and D to their appropriate unique geographic spaces with the Offsetter, then use the PointCloudCombiner.
Hope this helps.
Nathan
nathanatsafe
Forum|alt.badge.img+7
  • July 26, 2018
Hi @danilo_fme,
Hope this helps.
Nathan
danilo_fme
  • July 30, 2018
nathanatsafe wrote:
Hi @danilo_fme,
Hope this helps.
Nathan
Thanks @NathanAtSafe
Your answer was very helpful.
