Combine the lines if the line is smaller than certain amount
jugoslaviaa
Hi all,
I have street centerline dataset, In the datasets, there are some lines that smaller than 80 feet. I would like to combine those small lines with adjacent centerline. However, I could not find a way how i can use line combiner based on such condition.
The line in the image is 70 feet so i would like to combine it either the lines behind or ahead.
Any idea? Thanks in advance.
Best,
danilo_fme
Forum|alt.badge.img+49
  • April 16, 2019
Hi @jugoslaviaa
Inside the transformer LineCombiner there is the option Combine On Attributes:
Did you try this option?
Thanks,
Danilo
jugoslaviaa
  • April 16, 2019
danilo_fme wrote:
Hi @jugoslaviaa
Thanks,
Danilo
I need to combine a line with neighbouring line if _length is smaller than 80 feets. It seems to be to this parameter allows combine if the length of two lines are the same. Just added a picture.
you can use Aggregator and group by name, then use Deaggregator (that will give you a prat_number).
Then use tester (if the length is less than 80 feet : change the part_number to part_number minus 1)
after that you can combine lines using group by name and part_number.
jugoslaviaa
  • April 17, 2019
I have solved the problem with combination of Tester, NeighborFinder and LineCombiner. Thanks for the answers.
