combine text values with the stringconcatenator and ignore emtpy values
  • Sep 5, 2024 3:24 PM UTC
  • 167 views
maisels
Forum|alt.badge.img+3
Hello, i have a problem with the stringconcatenator. i would like to combine several values of text attributes with the stringconcatenator as a new attribute. the values should be separated by a comma, empty attributes should be ignored and there must be no comma at the end. how can this be achieved? I always get two or more comms if the attribute is emtpy. Thanks a lot.
Best answer by dustin
You can follow the StringConcatentor with two StringReplacers:
One using the following regex, replacing with a single comma.
,{2,}
The second StringReplacer will replace any remaining comma at the end with blank string using
Alternatively, you can do this in a single AttributeCreator using the following string:
@ReplaceRegularExpression(@ReplaceRegularExpression(@Value(att),",{2,}",",",caseSensitive=TRUE),",$","",caseSensitive=TRUE)
dustin
Forum|alt.badge.img+36
  • Sep 5, 2024 3:35 PM UTC
,{2,}
maisels
  • Sep 6, 2024 6:28 AM UTC
Perfect, that works great for me. 😃
Thanks  !
