combine surfaces when they are attached
  • Feb 21, 2019 10:12 AM UTC
  • 5 replies
  • 116 views
Hi ,
As you see in the image below ,i need to merge these small polygons to the bigger polygon beside,is there a way to do that?
Thanks!
  • Feb 21, 2019 10:16 AM UTC
If the small parts and the larger polygon have a common ID, you can use the Dissolver transformer with the common ID as the "Group By" attribute.
  • Feb 21, 2019 11:16 AM UTC
thanks @david_r for your answer , No ,they don't have a common ID ,no attributs ,just geometry
Forum|alt.badge.img+54
  • Feb 21, 2019 12:22 PM UTC
If you don't have a common ID to dissolve on you'll need to create some rules to determine which polygons should be dissolved together, e.g. you might decide that everything under a certain area should be dissolved to the adjacent polygon
  • Feb 21, 2019 2:06 PM UTC
thanks @ egomm but where can I find this option?
  • Feb 21, 2019 2:45 PM UTC
It's not a single option. You would have to find all polygons less than 100sqm, find which polygons neighbour them, choose which to merge with, assign a common id and then dissolve. Depending on the complexity of your data it can get quite involved
A simple example
dissolve_small_polygons.fmwt
