combine list in one point shapefile
  • May 9, 2019 1:07 PM UTC
  • 11 replies
  • 115 views
a_afiaax
Hello FME community,
I am quite a beginner with FME and I have point shapefile includes country names. Each country name divided into 2 parts and the 1st part ended with (-).
How can I combine a country name and remove (-) in the following list?
To this:
For each name sometimes 1st part sorted at end, for example Camb-
Does anyone have any ideas or potential solutions?
@takashi @david_r @jlutherthomas @egomm @mark2atsafe
danilo_fme
Forum|alt.badge.img+58
  • May 9, 2019 1:39 PM UTC
Hello @a_afiaax
I simulated here your case with the XLS Reader.
First: filter by attribute Name with symbol " - " - transformer StringSearcher.
Step 2: Create a attribute Order for each results from Output port Matched ( transformer StringSearcher ).
Step 3: Sroter by attribute Order and after Aggregator by attribute Point_ID.
Attached the Workspace Template - Workspace_String.fmwt
Thanks,
Danilo
Forum|alt.badge.img+63
So the general approach would be PointOnPointOverlayer to build the list, ListConcatenator to join the name values and then a StringReplacer to get the - out. But you need to make sure the list is sorted correctly, either by making sure the points enter the PointOnPointOverlayer in the correct order or by sorting it before the ListConcatenator. Otherwise you'd might end up with odiaCamb-
So I've added an extra sorting attribute, that's being filled with a conditional value: if Name ends in a - it's the first part, so it gets a 1, the rest must be the second part so it gets a 2.
And the entire workflow:
Note that this may produce strange results if the name of the country contains hyphens
a_afiaax
  • May 9, 2019 2:36 PM UTC
Hello @a_afiaax
Thanks,
Danilo
Hello Danilo,
1st AttrributeMangaer includes 2 attributes i cant understand them !.
The final result looks nice but missed 2 records (ID:10Z and ID:14B):
Do you have any idea to keep all IDs?
Thank you.
mark2atsafe
Forum|alt.badge.img+59
PointOnPointOverlayer? Do you need to do it spatially if there is an ID for the key?
a_afiaax
  • May 9, 2019 2:48 PM UTC
Hi @redgeographics , it end up with odiaCamb :
In addition to missing 2 record and 2 attributes (ID and Name):
Forum|alt.badge.img+54
  • May 9, 2019 3:12 PM UTC
I'd create the combined names by aggregating based on the Point_ID after ordering and then merge them back to get the output required
Combine_part_string.fmwt
jdh
Forum|alt.badge.img+41
  • May 9, 2019 3:23 PM UTC
Assuming the points are ordered so that the pairs are together (regardless of internal order), this can be done with a single AttributeCreator using adjacent feature handling and conditionals.
adjacentstring.fmwt
jdh
  • May 9, 2019 3:25 PM UTC
adjacentstring.fmwt
If the assumption is incorrect, then a sorter on Point_ID prior to the attributeCreator would do the trick.
Not really (but hey, I'm a spatial person)
Did you set the AttributeManager and Sorter up like the example?
a_afiaax
  • May 10, 2019 7:12 AM UTC
adjacentstring.fmwt
Hi @jdh
Thank you for this solution. It takes little pit to understand conditions but it amazing.
