Color by attribute value is not working in Chart Generator FME 2017
  • Oct 29, 2019 2:23 PM UTC
  • 104 views
saravanan
Forum|alt.badge.img+18
i have group of values with different color codes. When I run the transformer, it considers only first row color for all bars. Actually Bar colors should vary based on color attribute , Really appreciable if anyone can help on this ?
Best answer by mark2atsafe
Hi @saravanan
I checked and found that this was a known issue in 2017:
If the data enters the ChartGenerator unsorted the color assignments are
wrong, even though they are supposed to be read from the fme_color. First
wedge gets swapped with the last one. Sorting the data seems to fix this
but it's still counterintuitive.
So it sounds like you can workaround this by sorting the data, presumably by fme_color
However, the issue has now been fixed anyway. If you upgrade to FME2019.1 (build 19554 or greater) then you should find that the color works as intended.
mark2atsafe
Forum|alt.badge.img+59
  • Oct 30, 2019 7:58 PM UTC
Hi @saravanan
mark2atsafe
Hi @saravanan
Note to self: FMEENGINE-40260
saravanan
  • Oct 31, 2019 5:12 AM UTC
Hi @saravanan
Thank you Mark. I tried by sorting fme_color, but still the problem persists. Hope upgrading would be better solution.
