Close polygons at intersections
  • Jun 14, 2018 2:23 PM UTC
  • 83 views
Good morning!
I am trying to close walls at the intersection of another wall. I have tried using the anchor snapper to snap to the nearest lines, but it doesn't seem to fix all of them. Some walls are already closed. I have also attached my workbench.
Thanks!
David
gio
Forum|alt.badge.img+15
  • Jun 14, 2018 3:28 PM UTC
@david_prosack88
Use a area builder first. Not closed objects are routed trough the incomplete port.
On the not closed objects, try chopper to 2 vertices and then a Snapper (endpoint snapping with like 0.1 tolerance).(don't use line closer because there is no guaranty it will snap in its extension.)
Because if they are only open at a single spot snapping might try to snap two endpoints simultaneously to each other. (which often fails).
Most of you workspace is superfluous.
You have not posted your data set (or sample of it, I can't verify).
To include data you should save as template. Or upload a sample separately.
