clipping point cloud around a point
  • Sep 9, 2019 6:37 PM UTC
  • 43 views
arthy
Forum|alt.badge.img+8
Hello,
I have a set of points with x, y and z coordinates. I would like to create a buffer around those points and then use that buffer to clip a point cloud data.
How should I proceed? I tried to swap the Y and z coordinates and then perform a two dimension clip operation but it doesn't give anything.
erik_jan
Forum|alt.badge.img+26
  • Sep 9, 2019 6:44 PM UTC
To clip a Point Cloud, you will need a 3D clipper:
Create a buffer around the point, using the Bufferer transformer.
Than create a 3D buffer, by adding the height using the Extender transformer.
The 3D object can be used as Clipper in the Clipper transformer (using the point cloud as Clippe).
Hope this helps.
arthy
  • Sep 14, 2019 12:37 PM UTC
Hope this helps.
@erik_jan
Thanks for your reply. I tried this sever times but I think I'm missing something in your answer. Please could you provide an example of ETL doing that?
