Clipping and blending rasters...An easy method?
  • Feb 28, 2014 12:22 PM UTC
  • 8 replies
  • 196 views
is there an easy way to clip a raster based on a shape file with a feathered edge?
So use the "clipper" but not just end up with a harsh cut, as I want to merge this with another raster dataset and for them to blend in. or is the "Alpha Compositing: Blending Two Raster Images" method the only realistic method?
The effect i'm looking for is similar to that of a feathered lasso in Photoshop.
nrich_defra
Forum|alt.badge.img+7
  • Mar 1, 2014 10:27 PM UTC
Hi Ash, I'm no expert in dealing with rasters, however the way to 'feather' them would be to ensure that you're clipping shapefiles overlap and them use the alpha comositing as you say.
in effect resample the overlapping part of your images to 'feather' them?
gio
Forum|alt.badge.img+15
  • Mar 3, 2014 2:17 PM UTC
Yes, for blending with a alpha gradient u must create a composition map with buffered amount and radialy (if that is what u want) calculate the aplha strength.
Then raster combine the alpha map with your raster.
Wich is basicaly what photo software do btw.
  • Mar 3, 2014 3:33 PM UTC
Thanks for the responses guys. I shall give these a go
btl
Forum|alt.badge.img+12
  • Apr 2, 2019 1:21 PM UTC
Just wondering if anything has changed on this front in the last 5 years?
I have seen the MapnikRasterizer but blending seems awkward to set up, particularly if you have more than one layer to blend.
xiaomengatsafe
Forum|alt.badge.img+11
Hi @btl, Thanks for your question. There are a couple of methods that might be worth trying:
Here is an article explaining in more detail on how to blend two rasters: https://knowledge.safe.com/articles/1219/alpha-compositing-blending-two-raster-images.html
There is also a custom transformer in the hub, which might work better for your scenario involving multiple layers: https://hub.safe.com/transformers/rasterblendmosaicker#description
Full disclosure, I've not tried this workflow, but hopefully these resources might be helpful to you.
owen
  • Apr 3, 2019 7:45 PM UTC
The MapnikRasterizer has compositing operations and uses anti-aliasing which will give you a feathered edge to a feature. Not too difficult to set up once you understand the order of layers.
Its also worth looking at the RasterConvolver which adds a whole other set of image tools, such as Gaussian Blur
gio
  • Sep 25, 2019 11:37 AM UTC
@btl
Option would be to use (for instance) PIL. (which appears to be in the standard install)
Here is a simple blurr script. Blurs in 8 stages
(because of issues with the show method (which is commented out in this example), i used the webbrowser apporach to view it)
import fme
import fmeobjects
import webbrowser
from PIL import Image, ImageFilter # imports the library
def huh(feature):
original = Image.open("H:\\Documents\\My Pictures\\Manneke.jpg") # load an image from the hard drive
for x in range(8):
blurred = original.filter(ImageFilter.BLUR) # blur the image
fnb = "H:\\Documents\\My Pictures\\Manneke_b_"+str(x)+".jpg"
blurred.save(fnb)
#original.show() # display both images
#blurred.show()
webbrowser.open(fnb)
#original = Image.open(fnb)
gio
  • Sep 25, 2019 11:39 AM UTC
@btl
Here is a belning example using PIL (replace wiht our own pics)
import fme
import fmeobjects
import webbrowser
def huh(feature):
im1= Image.open("H:\\Documents\\My Pictures\\Manneke.jpg")
im2= Image.open("H:\\Documents\\My Pictures\\Manneke_b_7.jpg")
im3= Image.open("H:\\Documents\\My Pictures\\pdfpf.png")
target_mode = im1.mode
target_size = im1.size
zero=tuple((0, 0))
crop_t= zero + target_size
print("Targetmode is "+im1.mode+ " with size "+ str(target_size) +" and sourcemode is "+im3.mode+"with size "+ str(im3.size))
im3c=im3.crop(crop_t)
im_out = Image.blend(im1, im3c, 0.5)
#im_out = Image.alpha_composite(im1, im2)
i_name = "H:\\Documents\\My Pictures\\A_comp.jpg"
im_out.save(i_name)
#webbrowser.open(i_name)
