Clipping 3D object
  • May 30, 2024
  • 181 views
rednas40
Participant
I have a 3D buffer that I want to clip with a 3D object. If I use the 3D clipper then it will be only clipped in width, but not in depth. Any solution for this problem?
kailinatsafe
Forum|alt.badge.img+21
Hello @rednas40, thanks for posting! May I ask what version of FME you’re using? I believe 3D clipping was introduced in FME Form 2022.0, which can be found on the Downloads Page > Past Version. If you are already using FME Form 22.0, please consider sharing a sample dataset for testing. Happy to help, Kailin.
