Clipper attribute merge confusion
  • Feb 10, 2019 8:00 PM UTC
  • 5 replies
  • 107 views
Hello,
I am stuck on a problem that is probably very simple, I just don't get it...
  • I have a simple test IFC file with two rooms and some random furniture:
  • I would like to use FME to run an inclusion test, which furniture is in which room.
My thinking is to extract a center point of every furniture instance and run a spatial join using the Clipper tool. Something like this:
Now, the confusing part.
  • The clipper attribute merge is telling me all the furniture are in just one room:
Why is that?
It works fine using an AreaOverlay, but I really need a 3D inclusion test...
Test IFC and my workspace:
Thanks.
Best answer by markatsafe
@ras this is an issue with FME and we'll try and fix it. In the meantime, if you connect the output of your SurfaceFootprintReplacer to the Clipper input port then I think it will give you a workaround
  • Feb 11, 2019 6:32 AM UTC
It seems to be a defect in the Clipper. I would recommend you to contact Safe support to clarify the issue.
Report a Problem
Forum|alt.badge.img+54
  • Feb 11, 2019 9:13 AM UTC
It looks like the clipper geometries are actually getting rejected. I think you can only clip solids with solids. Still, it shouldn't give the appearance of having worked and features still exit via the inside port.
  • Feb 11, 2019 4:46 PM UTC
@egomm Hi and thanks for the reply, I can replace the chair instances with a BoundingBox (solid), result stays the same.
I guess it's a bug, or the Clipper was never intended to be used this way?
Which is a reall bummer...
Now I wonder, if there is a way how run an inclusion test using Python. I think Scipy has a convex hull function.
But it's kind of crazy that I have to DIY. :(
  • Feb 11, 2019 6:02 PM UTC
  • Feb 12, 2019 7:13 AM UTC
Thanks for letting me know.
