Clip polygons outside shape boundary
  • January 28, 2020
  • 120 views
kidega
Forum|alt.badge.img+8
Hello,
I am trying to clip polygons which are outside of a shape boundary. Basically as attached image, I'd like to clip/ erase all yellow selected polygons. The first step is working to clip ortho photo and generate polygon terrain from boundaries. But the "left" over polygons in between (with no ortho photo) are the ones which would need to be erased.
I've tried deaggregator to get all polygons from the generated terrain and feed into the clippee. The Clipper is the shape polygons from first image. No success so far.
I appreciate any ideas.
Thanks!
Forum|alt.badge.img+50
I think what's happening is that it clips the orthophoto but then writes it to a single raster anyway. If you have the option to group by e.g. a polygon id that might do the trick but I'm not familiar with Sketchup myself so I'm not sure of the details.
kidega
  • January 28, 2020
Hello #redgeographics.
Thanks for a hint on where to go. As an output it doesn't neccesary have to be sketchup. I'll check idéa of group by polygon ID. Do you refer next step of testing which poly ID has got a ortho raster or similar test? Do you also think the result should end up to have as many rasters as there are shape boundaries, instead of perhaps just one raster feature?
It depends on what you want really, if you want to write it to a single raster I'd try using a RasterMosaicker first, which should give you some more control over what to do with the areas outside the polygons.
As for testing whether or not there is a raster, do you think it's likely that some polygons will not overlap your original raster?
kidega
  • January 28, 2020
Okey thanks, will check RasterMosaicker and see how it goes.
...hard to say whether polygons will or not overlap. Guess there will always be a scenario for both events.
